讨论专栏主题﹕Android威胁iPhone 苹果祭出专利诉讼手段
朋友还在用滑盖式的键盘手机,想当年一支要价不斐,位居9999顶级手机之列,然而今天在众人面前拿出来用,还会觉得蛮丢脸的。是的,主流手机的面貌已经改变:上一代手机拼的是硬件功能,要愈多愈好;这一代手机比的是软件功能以及操作接口,屏幕大不用说,更重要的要有多点触控接口,而且要能下载多样的应用软件...
发 表 于: 2010.10.13 11:32:56 AM
文章主题: Re: Android威脅iPhone 蘋果祭出專利訴訟手段
发 表 于: 2010.10.13 11:45:44 AM
有保護套 手機可無線充電
傳統手機都要接上電線才能充電,現在手機充電,可以無線充電了。
台北南港展覽場的「台灣國際RFID應用展」中,有業者展示以電磁交換原理充電的手機充電檯,民眾只要先將充電檯接上電,內藏的天線與RFID晶片的手機保護套,可以將電流轉變成磁場變化,再透過磁場變化生成電流,手機可以直接充電。
無線充電技術已經可以做到對iPad(10W功率)充電,業者表示,明年目標是做到可以對筆電(100W)充電。
iPhone 4在台灣掀起搶購熱潮,導航王iPhone 4版在App Store一週內下載量破4萬人次,成為台灣地區免付費軟體下載量第一名,iPhone 4因內有陀螺儀整合功能,可以分辨坡度高低,能夠導航區別該走橋上還是橋下;也支援iOS4多工處理,可以一邊接電話,導航也不中斷。
发 表 于: 2010.10.15 11:41:25 AM
发 表 于: 2010.10.18 11:17:05 AM
发 表 于: 2010.10.19 11:28:06 AM
評論:鮑爾默的新三國演義   微軟、蘋果、谷歌成局
http://tech.weiphone.com/2010-10-18/Comments_Ballmer_s_three_bureau_Google_Microsoft_Apple_225034.shtml
发 表 于: 2010.10.21 11:35:46 AM
What Is Apple's Mission Control?
Apple's consolidating some of its key OS features—Expose, Dashboard, full screen apps, and Spaces—into something called Mission Control. But what is it, exactly?
It's a fancier Exposé...
As you probably know, Exposé has been saving people's time since OS X Panther (way back in 2003, would you believe). Mission Control builds on that technology, and actually incorporates Exposé to highlight all open programs.
...it consolidates everything...
Not only does it unify Exposé, but it also brings in Dashboard, Spaces, and those fullscreen apps Apple's now going to be selling (and giving away for free) via the Mac App Store. You can navigate to any part of your Mac instantly.
...and it'll be darn handy for apps, too...
Possibly the best part is that it'll group similar apps together. I've a feeling apps on Mac will be a big business, so being able to see stacks of similar apps (all the gaming ones together, for example), is going to cut down time for sure.
...though we have to wait a while for it.
Unfortunately, it's a long wait—it's going to be part of OS X Lion, which is out summer 2011. How much time is Mission Control going to save you, and how much do you love that name? It'll make computing feel all James Bond-y. [Liveblog]
发 表 于: 2010.10.21 11:49:03 AM
发 表 于: 2010.10.22 10:59:50 AM
Apple Really Doesn't Want You To Tear Apart A MacBook Air
The folks at iFixIt rushed to tear down the new MacBook Air, but they discovered that Apple apparently really doesn't want you to poke around the gadget. It's full of proprietary parts—right down to the screws.
Here are the highlights of the teardown according to iFixIt:
* The flip-open port door has been scrapped and the IR sensor and sleep LED are gone. In exchange, the new model manages to fit an extra USB 2.0 port along its right edge.
* Apple apparently doesn't want you inside this thing. They decided to use proprietary 5-point security Torx screws to attach the lower case. Once inside, the Air is held together with more normal 6-point T5 and T8 Torx screws.
* The battery is comprised of six individual lithium-polymer cells, which combine to form a 35 Watt-hour battery.
* Although in a different form factor, the new MacBook Air uses the same Broadcom BCM943224 Wi-Fi/Bluetooth chip as the current lineup of MacBook Pros.
* The back of the trackpad has a Broadcom BCM5976A0K chip on it, likely responsible for the multi-touch capabilities of the the trackpad.
* The 11.6" MacBook Air features a resolution of 1366x768. That's a few more pixels and noticeably more widescreen (16x9 vs 16x10) than the 1280x800 resolution of previous Air models. In a welcome improvement, Apple has substantially enhanced the rigidity of the display assembly.
As usual, you can find more gadget gore photos over at iFixIt along with a step-by-step description of the full teardown. [iFixIt]
发 表 于: 2010.10.25 11:21:58 AM
发 表 于: 2010.10.25 11:25:16 AM
可愛的iPhone擴音器
這款採用橡膠製成的iPhone擴音器不僅質量輕便,材質柔軟,就連造型都很可愛呢!更重要的是,應用了擴音物理原理設計的它無需能源驅動,即可幫您將手機播送的音樂,視頻聲音放大。只要將擴音器套入iPhone底部,它即可開始工作。為了不影響使用者的操作,即便是套上了裝備,您的iPhone主控按鈕位置依舊不受遮擋,數據連結線也可以通過預留孔洞接入,甚至於手機橫置,豎置也不會影響到擴音器的工作,它反而還能充當支撐底座,讓您使用起來方便不少。
售價:24.95美元
2010102203
2010102204
2010102205
2010102206
2010102207
2010102208
(patent-cn)
发 表 于: 2010.10.26 11:41:11 AM
Microchip推出面向边缘人工智慧应用的新型高密度电源模组MCPF1412
Microchip发布PIC16F17576 微控制器系列,简化类比感测器设计
DigiKey 在 2025 年第一季增加近 10 万个新产品导入 (NPI) 和 100 多家新供应商
DigiKey 推出自有品牌 DigiKey Standard 产品组合
从等结果到即时掌握! 宜特全球智慧可靠度验证中心,助AI产品抢得先机
车载ADAS系统新趋势
