討論 新聞 主題﹕我不是雞肋! 2D轉3D解決內容不足燃眉之急
3D話題延燒,在本屆Computex發揮得淋漓盡致。而為了解決3D內容不足的隱憂,參展廠商紛紛使出渾身解數,展示導入「2D轉3D」技術的產品,藉解決現階段3D影片來源不足問題來搶攻市場。 3D內容不足是3D電視的發展限制之一,因此發展2D轉3D的影像轉換技術已成為解決問題的捷徑...
發 表 於: 2010.11.09 10:41:24 AM
文章主題: Re: 我不是雞肋! 2D轉3D解決內容不足燃眉之急
Oakley 3D Gascan glasses revealed
A couple of months back we mentioned that Oakley would be releasing 3D glasses before the year ends. And just recently, they officially announced these Oakley 3D Gascan glasses that you can use with 3D moviehouses utilizing RealD technology.
With this pair, you no longer have to settle on using dirty 3D glasses used by hundreds of moviegoers already. You simply have to get your own pair of Oakley 3D Gascan and use it instead of the cheap, standard glasses usually being offered in theaters.
A pair of Oakley 3D Gascan glasses is priced at $120. Available in either white or black.
(techfever)
發 表 於: 2010.11.10 10:04:05 AM
手機拍出3D照片 日本迎戰iPhone
http://tw.news.yahoo.com/article/url/d/a/101109/8/2gl16.html
發 表 於: 2010.11.10 10:10:00 AM
NTT Docomo 3D Display System
Displays used in mobile phones, handheld games, and other mobile devices have shown remarkable progress as resolution has become sharper and clearer with each passing year. Now another breakthrough is stirring interest and excitement - the emergence of three-dimensional displays. Adding considerable new value to images and video, NTT DOCOMO has developed a portable 3D display system that enables viewers to view 3D images from any direction without having to wear those cumbersome glasses.
Traditional 3D display systems are based on the principle of stereoscopy, whereby the 3D effect derives from the difference between the images registered by the left and right eye as the result of their horizontal separation, a phenomenon known as binocular disparity. This type of 3D display has been incorporated into a host of products but is far from ideal because it usually requires viewers to wear special glasses to enjoy the 3D effect or, if 3D glasses are dispensed with, limits observation of the 3D effect to a very narrow range. The 3D display developed by NTT DOCOMO overcomes these shortcomings. Although we continue to rely on the principle of stereoscopy, we have adopted a new approach - known as high-density directional images display - that endows the object with very smooth and natural appearing motion as the observer's position changes (motion parallax) without the need for 3D glasses.
High-density directional images displays employ a large number of directional images - projections of a display target - with each image projected from a slightly different angle. As the viewer moves around the static display, the transition from one image to the next is so smooth and imperceptible that the viewer has the illusion of moving around a 3D object. Our most recently developed display allows objects to shift dynamically to match the viewing angle of the observer, and 3D action can be observed over a significant range (within a 60-degree horizontal angle and 30-degree vertical angle). A built-in camera senses the position of the viewer (the angle from which the viewer is observing the display), and automatically adjusts to that viewing angle in real time to maintain the 3D effect.
The 3D display is a high-definition liquid-crystal display to which a lenticular sheet has been attached, the latter essentially being a ribbed panel consisting of dozens of optical-grade cylindrical lenses arrayed in parallel vertical lines. The cylindrical lenses exhibit the 3D effect when viewed from a horizontal perspective, and diffuse light in the manner of ordinary glass when viewed from a vertical perspective.
In the case of ordinary 2D images, each point on the surface of a displayed object is represented by a single luminance value (pixel) in a one-to-one relationship, and viewers see exactly the same pixel regardless of the angle from which they are viewing the display. 3D images are fundamentally different from 2D images in that they have several subpixels. A cluster of multiple subpixels is known as a 3D pixel, and the lenticular sheet is attached to the display in such a way that each cylindrical lens overlaps several subpixels, each of which is emitting light in a different horizontal direction.
We think NTT DOCOMO's 3D display system has enormous potential. Objects have such a convincingly three-dimensional appearance that you want to reach out and touch them. We envision all sorts of imaginative applications for this technology to mobile phones including realistic games where the characters and images are rendered in 3D or mobile Internet shopping that allows customers to view potential purchases from virtually any direction.
How Display Works
*Click the image for a larger view.
3D image viewed thorugh lenticular lens
(nttdocomo.com)
發 表 於: 2010.11.16 11:22:49 AM
i3dg turns iphone into 3d display
How’d you like it if you could turn your iPhone into a glasses-free 3D display?
i3dg_iphone_3d_display
By using an old-school technique with a half-silvered mirror placed at a 45-degree angle, along with a special app, the i3DG Palm Top Theater turns your iPhone or iPodTouch into a 3D display. By splitting images or video into three layers using the template below, then reflecting them off of the mirrors, it creates the illusion of depth.
i3dg_iphone_3d_template
Here’s a quick video, showing off the i3DG in action:
The devices and demo videos were created by media artist Jitsuro Mase, and have been making the rounds at interactive art exhibitions. No word on if and when they’ll put the gadget into production, or if it will remain a prototype for now.
[via Japan Probe]
發 表 於: 2010.11.18 11:14:31 AM
Viewsonic 3DV5 Is a Pocket-Fitting 3D Camcorder
Viewsonic announced their mini-sized 3D camcorder last month, but now they've finally brought it stateside. Not only does the 3DV5 pack two 5MP fixed focus cameras for 3D 720p video, it's also got a glassesless 3D display panel for playback.
Of course, the 3DV5 has the same problem that all 3D camcorders and cameras do: you're going to have to get yourself a 3DTV or 3D laptop to watch it on. The good news is that this particular mighty mite can also record in 2D, making it as present-ready as it is future-proof. And it might just be worth the $180 to have your bases covered. [ZDNet]
發 表 於: 2010.11.18 11:19:18 AM
Panasonic's 103-Inch Plasma TV Goes 3D
After falling in price to "just" $50,000 last year, Panasonic's five-year-old plasma has been updated with 3D technology. The TH-P103MT2 will sell for the equivalent of $101,900 in Japan—not including installation, naturally. [AkihabaraNews]
發 表 於: 2010.11.18 11:21:24 AM
Sharp's Glasses-less 3D Phone Will Hit the US Next Year
Sharp's Glassesless 3D Phone Will Hit the US Next Year
Not just the US, but China and India as well. They haven't said which glassesless 3D phone it'll be, but we've gone on the record as saying their 3D isn't too bad. You know, for a novelty. [Mainichi via 3D-Display-Info]
發 表 於: 2010.11.18 11:36:35 AM
To 3-D or not to 3-D? 'Potter' people disagree
Radcliffe said he is delighted that the filmmakers and distributor Warner Bros. scrapped plans to convert "Harry Potter and the Deathly Hallows: Part 1" to 3-D. He also hopes they abandon their 3-D plans for "Part 2," due in theaters next July.
"If any film doesn't need a gimmick, it's these ones, and that's for me what 3-D is," Radcliffe said in an interview. "For me, 3-D adds nothing to the story."
It does add to the box office, however. Movies available in both two- and three-dimensional projection often derive two-thirds or more of their revenue from 3-D versions, with fans willing to pay the few dollars extra it costs to put on the dorky glasses that bring the illusion of depth to the images.
The filmmakers had been racing to create a 3-D version of "Deathly Hallows" in time for its theatrical debut this week, but they said they ran out of time to do it right.
"We lavish a huge amount of attention and care on the 2-D version, the normal version of the film," said producer David Barron. "We were just not prepared to throw off what you might call some half-assed version just for the sake of trying to generate more money."
How much more money? There's no way to pinpoint precisely what 3-D would have added to revenues for "Deathly Hallows," but producer David Heyman made an estimate.
"I think 10 to 20 percent, probably. On a film that's going to make $800 million at the box office, that's a lot of money," Heyman said. "Warner Bros. are going to have to alter their fourth-quarter projections because it's not in 3-D."
As bad as that sounds for shareholders, it's a rare instance of quality trumping commerce in greedy Hollywood. Warner Bros. pushed for a 3-D version but ultimately agreed to drop it once the filmmakers convinced studio heads it would be an inferior rush job.
Director David Yates, who shot both parts of "Deathly Hallows" simultaneously, said "lots of beautiful individual bits and pieces" of "Part 1" had been converted to 3-D, but other scenes simply did not look right.
With what the filmmakers learned on "Part 1" — and nearly eight months ahead of them — they are confident they can deliver a 3-D version of "Part 2" that lives up to the "Harry Potter" brand name.
"I think it's going to be really cool," Yates said. "We've been working with people since May on the whole 3-D thing, so it's not like we're starting from scratch. I want it to work. I really want it to work."
There are moments in the 2-D version of "Part 1" where the possibilities of 3-D can be clearly seen, including a scene where a giant snake hurtles itself at the camera and another where Harry's pet owl flies away from him toward the audience.
Such images were not created for 3-D jolt effect, though, since "Deathly Hallows" was not shot with 3-D in mind. The film was well into production before the digital 3-D craze took hold last year, culminating in James Cameron's sci-fi sensation "Avatar."
Digital 3-D comes in two basic flavors: Films such as "Avatar" specifically shot with 3-D cameras that create two slightly offset images, and movies converted to 3-D after the fact.
Done well, footage converted to 3-D can look great. George Lucas showed an impressive 3-D conversion of the opening scenes of 1977's "Star Wars" to theater owners at a convention in 2005, and the technology has advanced since then.
Lucas plans to release 3-D versions of all six "Star Wars" movies, while Cameron is converting "Titanic" for 3-D release.
As meticulous as Lucas and Cameron are, fans probably can expect top-of-the-line 3-D conversions. But some recent movies converted to 3-D have come off as hasty knockoffs to cash in on 3-D mania.
Critics carped that 3-D added little to such recent hits as "The Last Airbender," "Clash of the Titans" and even Tim Burton's blockbuster "Alice in Wonderland." Some claimed 3-D conversion jobs actually can be a distraction, leaving images looking smudged and blurry.
Radcliffe is not a fan of 3-D even when it's done well. He said that Christopher Nolan's sci-fi blockbuster "Inception" was the year's best film both visually and dramatically, "and that for me puts the 3-D argument to bed."
"`Avatar,' sure, it looked amazing, but not more amazing than `Inception,'" Radcliffe said. "And I thought about `Inception' for so much longer because it was a better film, because it was a more interesting film. And I don't think that technology is a substitute for story, which I think is how 3-D can sometimes be used."
Nolan, who also made "Batman Begins" and "The Dark Knight," is not shooting his next Batman movie in 3-D, either.
Warner Bros., which released "Inception" and the Batman movies, may be counting on a 3-D bonanza from next summer's finale to the "Harry Potter" franchise. Yet Radcliffe would like to see "Deathly Hallows: Part 1" work enough critical and commercial magic that the filmmakers and studio bosses will change their minds.
"What I'm hoping is that this film will get a good enough reaction so they all go, `Maybe we don't have to do the last one in 3-D. People don't miss it.' That's what I'm hoping for," Radcliffe said. "But it's sort of not in my control."
發 表 於: 2010.11.19 10:18:54 AM
以色列VisualDomain全球首發的3D瀏覽器:Venus(金星)
http://tech.weiphone.com/2010-11-18/Israel_s_world_premiere_3D_browser_Venus_226699.shtml
發 表 於: 2010.11.23 11:03:56 AM
發 表 於: 2010.11.25 11:45:57 AM
O Gather 'Round Ye Comcast Yule Log On Ye 3DTV
O Gather 'Round Ye Comcast Yule Log On Ye 3DTVIt's true—Comcast's infamous yule log TV channel has gone 3D for the festive holiday season. Tune in, spike the eggnog and cop off with your sister's best friend. It's how Father Christmas would've wanted it. [Comcast/Image: Patrick Cecilian]
[上一頁]     1  2  3  4  5  6  7  [8]  9  10   [下一頁][下10頁][最後一頁]
關鍵字: 3D顯示   Computex 2010
[分析]以低成本UHD TV打開市場
[分析]以低成本UHD TV打開市場
液晶電視迎向Open Cell新世紀
兩岸觸控技術那裏走?
OLED照明殺手應用:防癌
產學研合力打造高速低耗能雷射源 迎接AI未來之光
工研院探討2025全球科技業競局 聚焦半導體、零組件與量子科技
南臺科大攜手工研院開發AI羽球教練系統獲CES 2025國際雙料大獎
量子國家隊聯手仁寶 開發退火運算應用
Touch Taiwan 2025展4月16日登場 聚焦電子紙、PLP面板級封裝
公共顯示技術邁向新變革
大眾與分眾顯示技術與應用
使用三端雙向可控矽和四端雙向可控矽控制LED照明
智慧控制點亮藍牙照明更便捷
適用於整合太陽能和儲能系統的轉換器拓撲結構
